FruityLoops Express?
Has anyone here used this product? I just need to be able to make some simple music and effects for my Flash animations, maybe also make loopable bits and was wondering if this might be a good place to start.?Only $49. They have the 'Fruity' edition for $99 but even with the featur comparison, given that I know nothing about sound, not sure what edition I should -looking to do what I want with least expence.
						Hi Bupaje,
I have the Producer Edition of Flstudio (was called Fruityloops in the past)
Download the demo and check it out.
There are so many music production software outthere, its difficult to say if this is the one for you.
hmm..you may want to play with one of the magix music programs..music maker is much simpler than music studio.
there is also synapse audio's Orion, Sony's Acid.
I own most of the above and they all good in their own ways, much like animation software.
i would strongly advise checking the demo software out first, see which gets you working quicker.
I'm a musician as well as an animator and wanted for a long time to find a no nonsense midi programming app that was NOT complicated. I found this prog called Superjam. It's free. You can create hundreds of styles easily as well as get into and play with the guts of your song of you want. I use it to quickly churn out a midi file for a backing track and then output the midi file through a tone generator to make the drums and other sounds more realistic. I've made many jingles with it for TV. Just remember it's great for spitting out quick midi files. If you want a better result you need to get hold of a tone generator like Roland Sound Canvas. Superjam can be downloaded from this link -
http://www.musicmachines.net/faqsj.htm
Have fun
D.K
Have fun
D.K
I've done a little music here and there. Please check my links.
Very complicated question you have there. I'm assuming you don't want to spend a lot right now and need this to be simple.
If you're on a Mac, Garageband might be worth looking into. If you're on a PC, there is Sony Acid. These two might be the easiest if you are not a musician. I believe they both have "lite" versions that you can then upgrade as you grow.
The one thing that in my honest opinion I would not recommend is wasting your money on the Sound Canvas. Absolutely NOT necessary in this day and age and you can get excellent results using software only. Unless you have a very old and weak computer. I only use a 1ghz piii for my music and I do okay though, so I imagine you should be fine.
No offense to DK and nothing against Roland... I have a lot of hardware items, including Roland as well - but I also have a lot of software items. Just trying to save you a few bucks.
As you can see from this thread... there are a lot of options and a lot of different user experiences. If you want to get even more opinions... check out www.kvraudio.com
Cheers, and good luck!
Thanks again. Tried out a few before work. Very cool. Sony Acid has a free version that allows ten tracks and seems easy to use. Since I am in school I can get the Academic version of it and some loop collections so it is pretty attractive.
Do any of these programs allow you to view as frames (setting frame rate) so it is easier to match audio to my Flash animation?
						Flstudio does have a basic video plug in , but its not free..well the demo is excluded but..
It really depends how much you are really to spend.
Sony also have recently released Cinescore.. which is based on acid and i guess vegas.
it is for film scoring but i guess its a bit expensive..
however, if you can get an academic price on Sony software..then maybe its a worthwhile option
http://www.sonymediasoftware.com/produc ... p?PID=1013
I really like FruityLoops (and FLStudio, although their old promise to provide eternal free upgrades to owners, and then throwing that out the window by changing the name slightly and saying "hey, it's a new product" was extremely cheeseball of them), it's got a huge number of things you can do with it. But their documentation is pretty deficient, and there a probably hundreds of features that you'll only find by messing with it endlessly. I haven't really done that, but my brother has, and if you get it and need some tips, I'll throw any questions my bro's way. But the basics are easy to pick up.
						Thanks. I tried the demo of FL Studio. It seems complex to start but loads of power. I think I will start with Acid Express as it seems easier for a novice but even with the little playing I did with FruityLoops I can see I will get this as soon as I get some experience; seems to have a lot of horsepower in there once you know what you are doing.
