How does audio bone wiggle work?
Locked
Daniel Poeira
Post by Daniel Poeira »
The subject pretty explains it all. I tried selecting the bone, then used the script, selected the audio file I wanted, MoHo created the keyframes on both the bone position and movement layers... but then I hit play, and nothing happened. What did I miss?
Lost Marble
Post by Lost Marble »
First of all, keyframes should only have been created in the Bone Angle channel. There's also a channel for the selected bone's angle, but these two channels are basically showing the same thing. You should not see keyframes in the bone position channel.
Next, do you have QuickTime installed? If you use this same audio file as a soundtrack for the animation, do you hear anything when you play it back?
It sounds like you're doing everything right; I'm not sure why the bone isn't moving. What did you use for the "Max angle" value when using this script?
Locked
