Export and Import Styles from one Moho file to Another
sherlock
Post by sherlock »
How do I Export and Import Styles from one Moho file to Another? I created all of the styles I wanted to share between project, then imported the layer from the file "styles.moho" into my current project as a moho object. I was hoping at least to be able to copy and paste the setting in the styles file, but none of the styles came over with the layer.
How can I share styles across Moho projects?
Thanks in Advance.
Lost Marble
Post by Lost Marble »
When you import a layer from one Moho file into another, only the styles used by that layer will be imported with the layer itself. So, if you're creating a kind of "style library", create a layer with lots of cirlces or squares or something, each one with a different assigned style. Then, when you import that layer, all the styles will come with it. After importing, you can delete that layer and the styles will be left over.
Guest
Post by Guest »
Perfect. Thanks!
