Layer Shading Effect, Pixelate the Border of any Shape.txt
Locked
Rai López
Post by Rai López »
I´m trying to get a "paper cut volume effect" in every shape of my animation, for this I've aplied a small Shadow Effect (4, 2, 0, 128 Black 315º) and a small Shading Effect too (4, 2, 0, with 128 White 135º) in every layer... Well, when I render the animation, an UGLY teeth (pixelate) border appears, and it become more intensive when shapes has not outline and even more when this shapes are over of another dark shapes; seems like the AA doesn't works very well with this effects applied...
Otherwise, seems too that AA is less effective over fills than over outlines (¡!) and this is a SERIOUS problem, because NOT always you have to want an outline in your shape... Well, I know that I can use an outline with the same color than fill to avoid this, but definitely this is NOT very practice... (perhaps if you can Drag & Drop colors from one Check Color Box to Another it'll be...)
Locked
