render window - cancel as default
rhenson
Post by rhenson »
dear LM,
I suggest to have in the render-window a cancel tab which is "highlighted" by default, in order to close that window by simple pressing enter.
Because in most of the cases, we need to render to control our work. After a quick ckeck, we will close the render window, and continue to work - until the next render check.
In former version of MOHO there was this cancel tab. Now I have to close the window by mouse click or by pressing alt+f4. I found it really bad for my workflow.
thank you. regards.
Lost Marble
Post by Lost Marble »
Actually, you can just press the Escape key to close the render window.
rhenson
Post by rhenson »
Great. This will serve me a lot.
By the way, is there a reference out with all shortcuts ?
Thank you. Regards
Hiddicop
Post by Hiddicop »
Well.. If you check the helpfile you will find that there, in the appendix, is a list over shourtcuts.
Lost Marble
I don't think this one is listed there, but pretty much everything else is.
