Problem with text & ÅÄÖ
izmo
Post by izmo »
Hi there
Thank you of this new version of Anime Studio
Still in need with on more option if it is possible.
Chars in european languages like åäö & ÅÄÖ
so that these could be typed in textfield trough
DRAW -> INSERT TEXT...
keep on good workin
and make some good animations
-izmo
Patmals
Post by Patmals »
Izmo, your right!
I was hoping to use Japanese text but..i couldnt
i tried with both "draw text" and the "credits" script..
they just turn out like squares and triangles..
maybe you would need to create them in another vector graphics package and import them back?
Rasheed
Post by Rasheed »
Of course, there is always the workaround of creating the accented characters in a wordprocessor and copy them through the clipboard (or, as in this case, copy the text from within a web browser window).
Patmals
Post by Patmals »
Rasheed wrote:Of course, there is always the workaround of creating the accented characters in a wordprocessor and copy them through the clipboard (or, as in this case, copy the text from within a web browser window).
Thanks Rasheed! I will try that!
Patmals
Post by Patmals »
I just tried it from Photoshop as an eps file and that worked quite okay!
But i havent tried the copy and paste method yet!
izmo
Post by izmo »
Hi there :wink:
Thank you for your quick answer
it works ok with short textfields
but with larger amount and updating them
well it sounds...just and just
thanx it works anyway
Maybe someday...
-izmo
rylleman
Post by rylleman »
There also is an issue with files that contains any special characters in their filenames. If you try to import an image file for example, you'll get the "broken image"icon in the work area.
Unfortunately this is still an issue in 2006 for several software packages, operating systems, and network/server-combinations. *sigh*
There's the workaround to use 7-bit-ASCII only for filenames, but it constantly annoys me.
Jbot
very disappointing
Post by Jbot »
I was told by E-Frontier's technical support that Anime Studio does not support unicode. Now how is that possible in 2006? I hope there will be a fix soon. Imagine not being able to save your file with eg. Scandinavian letters. :(
John
