Gradient animation doesn't create keyframes
Locked
Rai López
Post by Rai López »
Well, it seems that in the gradient effect we can now animate the gradient colors and orientation... it's great, but seems that this animation doesn't create any keyframe in the timeline window and there is no way of re-adjust easily after, a pity...
Lost Marble
Post by Lost Marble »
Animated gradients have been possible in previous versions of Moho as well. It's true that this isn't represented in the timeline in any way, so it is difficult to adjust an animated gradient later on.
This feature should really only be used in limited cases where you know how you want to set up your animated gradient, and then plan to leave it alone after that. If you need to make big changes, it's probably easier to remove the gradient, add a new one, and apply the new settings.
2ner
Post by 2ner »
I didn't know you could animate gradients. That's great! Would it be possible to make it add keyframes in future versions?
Lost Marble
Anything's possible, but I can't tell you what will or won't be in future versions.
Locked
