I posted some comments on storyboards some time back. Looking at your boards, places for scene numbering, dialoues, timings and backgounds etc are missing.
here is one which I use at work - it probably has more than you need (its a 16:9 format - is anyone using anything else?).
Master artwork is
here
Here;s one I dun earlier - part of a short film I am working in:
These scenes are finished. The reason the BG and [T]iming panels are blank is because there are no backgrounds - the're all vectored and 2/ the timings are flexible - they were worked out on a
excel form.
The storyboards are prepared on a DTP program - photoshop is a pain for  manipulating text - I am using Serif's PagePlus 9, both cheap and cheerful but gets the job done fast.
The action and dialogue are copied across from the script file (Final Draft).
The great part is the DTP originals are A3 sized. But because the file is output as pdf, I can autoscale down to A4.
By having all the action and dialogue listed, it helps when I give it to the producer or other animator - all the story is there in both works and pictures. Avoids confusion.
Hope this helps someone.
Rhoel.
