vector colouring/shading
- spasmodic_cheese
what is your technique for colouring in moho...
atm I am tracing my images... then i create a shape... then i start drawing my shaded/highlighted areas from the edges of that traced shape.. then select those points and make it a different colour... however this is illegal in flash export...
So i've have to delete athe main shape and recreate it, unfortnatly
becuase of all the points ive created during shading its very hard to select this distorted main shape... and taking alot of time.
Now when i have trouble in moho like this, its usually because its my lack of knowledge(im dumb).. but this im not so sure about.. so please enlighten me!
Am i missing a quick way to select prespective shapes areas?
I think it may actually be less tedious for me to import(did a cool chill go down my spine??) and fix imported artwork up in moho.
You can name your shapes within a layer. You can do this by:
- Whip out the Select Point tool,
- Select Your shape (make sure you have all the points)
- And in the top tool bar (come under the 'File' 'edit....' part) you'll see a box you write in. Type the name of the shape, and click create next to it.
- Now if you want to go back to that shape later, In either 'Select Points' , 'Translate Points' , 'Add Points' , Curvature' , 'Magnet' , 'Fill' Tools, you can click on a drop down box titled 'select group' and click on the desired shape and badda boom fo' shizzle bling, your shape shall appear and only that shape.
Hope this is to help with your points selecting problems.
--Scott
cribble.net
cribble.net
- spasmodic_cheese
You might try putting your highlighting and shading on a separate vector layer.
That would quickly solve any selection issues. If you wanted, when you were satisfied with the drawing, you could copy the highlight and shading shapes onto the original drawing layer. But I would think keeping them separate might make it easier to modify later. Also, if you did it like this and used the original layer as a mask, you wouldn't have to worry about following the outlines exactly, which should speed the precess up for you..
--Brian
--Brian
- spasmodic_cheese
- Lost Marble
I'm not sure what exactly is the difficult part - if you could post a sample file and describe which shape you're having trouble filling, we could all probably give more specific tips.
Here's one tip though: for many shapes, if you just select one or two points, and then press the Tab key, all the connected points will get selected. (The Tab key is a shortcut for "Edit->Select Connected".) This doesn't work for shapes that have been welded to neighboring shapes, but for many shapes it's a very quick way to select them.
- spasmodic_cheese
that tab thing works well, but still not what im getting at
http://www.peoplewhoeat.com/moh5/demony.moho <- exports to swf fine, but PAIN in the ass to setup
See the body layer
i want to go around it and do shading. the body is filled with that green, I found that if i now make points off that body , fill it in with a shape, export to flash it will produce some glitchy error in flash player.
so what i had to do is delete the shapes, make the points for where shading it, then create all the fills for the shaded areas, then try and select all the points for the main body to fill it, but the body shape gets more and more complex, so its harder to select, and if i do the tab thing it selects all the points.
I just reproduced the glitchyness, thats with one shape over the other
http://www.peoplewhoeat.com/moh5/demonyglitch.moho
export that to swf
See the body layer
export that to swf
- spasmodic_cheese
- Lost Marble
OK, here's another tip: with the Create Shape tool, if you click on a curve segment (between two points), that entire curve will be selected. On the body shape in your file, if I hold down the shift key (to select multiple objects), I can click on three curves to select the entire outline. Then, I need to click on four or five interior points to de-select them.
About eight clicks total, not too bad. I'm not sure how you could make it less, with all the interconnected shapes you have for shading effects. If those "shading shapes" weren't attached to the main body shape, it would be a lot easier to select just the body. As it is, selecting just the body is still not too many mouse clicks.
- spasmodic_cheese
ahh yes perfect!
Now i just copy a section of bodies curve... drag it away... make my shading... drag it back over body layer and remove outlines..and I group every section of points i make =P
I have no idea why i didn't make them seperate before
Its fun(after the frustration) to unlearn ways of doing stuff and relearn them
Okay well im off now, hopefully when i return I will have some cool stuff to show you!
