Finding and deleting points on interpolated switch layers.
I use to find it hard to find and delete or add points to multiple switch layers.
My problem was that the points change position so much I couldn't tell if I was selecting the correct ones on each layer.
I started recently using the follow technique to make this a bit easier.
If this has already been covered... I apolgize for the redundancy.
http://www.lowrestv.com/moho_stuff/dele ... oints.html
Hi Heyvern!
Thanks for the tip. It helped me in two ways. One the selection thecnique it self and other oppened my mind into switch layers used for 3D turning thecniques.
¡¡¡Thaks a lot for share knoledge!!!
Gracias por el truco. Me ha ayudado de dos formas. Una la técnica de selección por si misma y la otra la apertura de mi mente a las switch layers usadas para técnicas de giros 3D.
¡¡Muchas gracias por compartir conocimientos!!!
