obj files
nelsonscat
obj files
Post by nelsonscat »
I save my obj files in the same folder. I can import the file format, but I can't see it. How come?
first, with what software you work?
i always work with 3d, with teddy, chameleon and wings3d.
your object can't be sight beacuse it hasn't texture. if you work in wings, before export, you must transform color to material.
that's all.
Rhoel
Post by Rhoel »
I have also had a problem in viewing because the object is too big or too small - try zooming the work area in or out, just in case it the object is there but you are looking at a white object in close up.
Rhoel
there is a script in moho to scaling 3d object.
