can't import 3D object
Locked
ucup
Post by ucup »
hi everyone....
this is my first time joint this forum.
Now i am use MOHO5 and i get some problem with import 3d obj,
i used 3D wing for the object and gile's for the texture and light,but when i imported to MOHO5,the object can't be rander with the map and light,the object be came white on all surface.......
any body can help me?
Thank very much! :oops:
never give up
Lost Marble
Post by Lost Marble »
Gile[s] has a little problem exporting OBJ files. If you open an OBJ file that Gile[s] exported in a text editor, you'll see a line near the top that looks like this:
mtllib C:\Documents and Settings\Username\Desktop\myobject.mtl
Change this line to look like this:
mtllib myobject.mtl
The other problem is that Gile[s] will create two OBJ files - one for the texture and one for the lighting. Moho cannot combine the two objects. The best approach would be to combine the lighting and the texture into a single texture map on a single object, but I don't know if Gile[s] can do that.
Locked
