Opacity
Haki
Opacity
Post by Haki »
I would like to change the opacity of an image,but can´t find the right button :D. I hope it exist a button for opacity :idea:
Haki
Opacity for an image layer is the same place as for all layers. Double click the layer and set the opacity.
The main confusion is that the opacity of an image layer does not show in preview! You must render to see the opacity.
It took me a while to track that one down at first. ;)
Haki
Post by Haki »
Thanks Vern! But i need it for tracing. When i construct my model on top of the image i can´t see my line exactly....it makes me crazy :?
Haki
Haki
Post by Haki »
Ohhh ok i found it! :P I´m an idiot :roll: I should better search before i ask :D Sorry!
View -> select tracing image :oops:
Yeehaa!
I do the same thing.
But I draw a white box on a vector layer OVER the image layer. I then set the opacity of the box layer... works like a charm.
Under view there is also a "Tracing image" function. I don't like it though because I can't move the image or change it's size or opacity.
Haki
Post by Haki »
:D Thanks for your advice! :idea: Sounds better than tracing image.
Haki
