ScalePoints problems
len
Post by len »
Hi all.
I'm fairly new to scripting and was trying what seems to be simple.
I am accessing the points in a mesh and I want to scale them.
I'm using this code:
mesh = moho:Mesh()
mesh:SelectAll()
mesh:ScalePoints(4, 4, mesh:SelectedCenter())
Everything goes through fine and all the points are selected, but no transformations. I am expecting the points to separate by 4 times their current position relative to the center. Nothing at all happens besides being selected.
Any ideas what I'm missing here? Thanks!
Fazek
Post by Fazek »
mesh = moho:Mesh()
mesh:SelectAll()
mesh:PrepMovePoints()
PrepMovePoints copies the actual fPos variables into fTempPos for the points and ScalePoints reads fTempPos and writes fPos when operating.
- - - Fazek
len
Post by len »
Wow, thanks for the quick reply Fazek!
I tried your fix but there still seems to be something missing.
Here's the code I'm trying and I still only get the points to select but no movement. Is there anything I have to do AFTER the ScalePoints command? It's definitely getting to SelectAll since I see the points select.
Any other conditions you can think of that would make the scale fail?
mesh:SelectAll()
Thanks!
len
Post by len »
In case someone wants to check out the full script, here it is, a menu script. I'm still baffled as to why it doesn't do anything!
-- Provide Moho with the name of this scrippt object
ScriptName = "LW_SCALE_POINTS"
LW_LuaUtils = {}
LW_SCALE_POINTS = {}
LW_SCALE_POINTS.MAJOR_VERSION = 1
LW_SCALE_POINTS.MINOR_VERSION = 1
function LW_SCALE_POINTS:Name()
return("LW_SCALE_POINTS")
end
function LW_SCALE_POINTS:Version()
return "" .. LW_SCALE_POINTS.MAJOR_VERSION .. ".".. LW_SCALE_POINTS.MINOR_VERSION
end
function LW_SCALE_POINTS:Description()
return "Scale points in a layer"
end
function LW_SCALE_POINTS:Creator()
return "Len White"
end
function LW_SCALE_POINTS:UILabel()
return "LW: Scale all points in layer"
end
-- Recurring values
LW_SCALE_POINTS.file = {}
-- The guts of this script
function LW_SCALE_POINTS:Run(moho)
local curLayer = moho.layer
local mesh
if ( curLayer == nil ) then
return
end
local curLayerType = curLayer:LayerType()
if ( curLayerType == MOHO.LT_VECTOR) then
mesh = moho:Mesh()
mesh:SelectAll()
else
return
end
end
7feet
Post by 7feet »
One more addition...
	local mesh
		return
	end
		mesh = moho:Mesh()
		mesh:SelectAll()
		mesh:ScalePoints(.5, .4, mesh:SelectedCenter())
		moho:AddPointKeyframe(moho.frame)
	end
end
Seems to do the trick. Guess Moho doesn't think it's real until you create a keyframe.
len
Post by len »
Awesome! Thanks 7feet! That totally did the trick. I'll keep an eye on that keyframe issue from now on.
