Morphing
Locked
stingslang
Morphing
Post by stingslang »
Does Moho have support for morphing?
no, he doesn't.
you just can create a switch layer and put inside it different vector layer with the same number of points to make something like morph.
(you must be sure that the "interpolate frames" be on)
The400th
Post by The400th »
I disagree - the results you can get are at least as good as the morphing features in other software.
So I'd say you CAN do morphing.
PS I'm talking about vector morphing, not bitmap morphing.
mmmm...
ok, if you want, you can make morphing by your self...
yes, the possibilities that have your self are infinite, it's just thing of propose it. and, you know, moho is too a frame by frame animating software (if you want).
Locked
