3D motion and Flash
- toulouse2k
3D motion and Flash
Since your upgrade price is so super-reasonable I plan to upgrade as soon as I take Moho 5 for a test drive. But I do have one question for now. I remember when I tried to do some 3D type effects (ie. moving into the stage past objects in the foreground) and tried to convert it to a .swf file...Flash was pretty balky about it and it didn't work well. Does it work any better now? It's not a make or break thing, since I really don't do that much Moho to Flash stuff anyway...but I'm just curious. Thanks for your time and advice. BTW, I'm using Flash MX 2004.
- spasmodic_cheese
You could use Mohoptimize to cut down your swf animation:
http://www.lostmarble.com/forum/viewtopic.php?t=443
Unfortunatly 3D movement in moho has to be exported frame-by-frame, you might want to change your framet rate in moho to something like 12... so it will only export 12 frame for each second, makes file size smaller.
Check Moho Help files > Reference > Flash Tips for what can and can't be exported from moho
- Lost Marble
- toulouse2k
