Tutorial Bug or Feature?
Roy
Post by Roy »
Hi, As suggested I followed through the tutorials. The section where you import frank and add a skeleton caused me some problems. I did everything right, but when pressing manipulate bones, frank did not move. I found that if I put one of the trees into franks place (dragged in as a sub branch of skeleton) that animated ok. I found I had to select all franks points and press 'flexi bind points'.
My Frank looked slightly different to the tutorial, it occurs to me that maybe 'my frank' is from a version earlier to 5?
Not sure why this happened. Frank was imported, the tree was created manually (as described in the tutorial). This may seem a small point to raise, but I can see if frustrating brand new users.
Thanks for a superb program, I have been telling lots of people about it!
Roy.
Errr. Um.
Lost Marble
Post by Lost Marble »
Did you install Moho 5 on top of an older version? If so, you probably had a leftover copy of "Tutorial Extras.moho". The old version resides here:
.../Moho/Tutorials/Tutorial Extras.moho
The new version that the tutorial asked you to use should be here:
.../Moho/Tutorials/1 - Basics/Tutorial Extras.moho
If you have an old copy still around, and you got Frank out of that, that would explain the bone problem, as well as why he looks different from the manual's pictures.
Roy
Post by Roy »
Ah- Yes, there is a 'tutorial extras' in the root of tutorials, and the new one is in 1-basics. Thanks, newbies obviosly wont have this problem.
Errr. Um.
