Render Farm
Locked
stingslang
Render Farm
Post by stingslang »
Is there any way to use Moho with a Render Farm?
Lost Marble
Post by Lost Marble »
Yes. Moho can be run in command-line mode. There's no specific support for network rendering or splitting a job between multiple computers, but the command-line support lets you set this all up using your own render farm software. Here's more info:
http://www.lostmarble.com/forum/viewtopic.php?t=1318
J. Baker
Post by J. Baker »
So all should work except "-v" for windows? I'm currently writting a small app for windows so a job can be render without opening Moho using your command line options.
Lost Marble
Yes, that's right.
J. Baker
Post by J. Baker »
Lost Marble wrote:Yes, that's right.
Thanks for the reply.
And to stingslang. I'm releasing my app tonight but I don't believe it's what you're looking for, as of right now. But you'll be able to render your moho files without opening moho itself. Here's a screenshot.
J. Baker
Post by J. Baker »
Ok, not sure what's happening here but the command line option doesn't work when I start adding options.
I can render this fine...
"C:\Program Files\Moho\moho.exe" -r MoonJump.moho
but as soon as I add an output and format it doesn't.
"C:\Program Files\Moho\moho.exe" -r MoonJump.moho -o C:\Documents and Settings\Owner.FLASHPULSE\Desktop\render_test.mov -f QT
Any suggestions?
jorgy
Post by jorgy »
Are you able to get an error message from your dialog box?
J. Baker
Post by J. Baker »
Ahh, it's always the simple things. I forgot the quotes around the output. I didn't see it in the example so I thought it didn't need it.
jorgy
Post by jorgy »
And looking at it closer, I bet you need double quotes around your arguments:
"C:\Documents and Settings\Owner.FLASHPULSE\Desktop\render_test.mov"
since there is a space in there.
jorgy
J. Baker
Post by J. Baker »
Yes indeed. You must have missed my post above yours but thanks for the help. Everything is working fine now. All I have to do is complete the start and end frame options and it's done. Well, it needs an icon. :wink:
jorgy
Post by jorgy »
I think we were posting at the same time. :-)
Glad you figured it out.
Locked
