A few questions: network render, transferring actions
kingace
Post by kingace »
Hello,
I was wondering if it was possible to:
1) Do a network render (let all networked computers share the render)
2) Transfer Moho's actions from one file to the other
Thanks in advanced!
jorgy
Re: A few questions: network render, transferring actions
Post by jorgy »
kingace wrote:Hello,
It is possible to do a render on the command line with moho. You will need to break out individual pieces of your animation into chunks to do a network render (i.e. moho can't break up a file for individual machines). But you can have individual moho files rendered on separate machines at the same time with the command line interface. Let me know if you need details on how this would be done.
jorgy
rylleman
Post by rylleman »
If you use a render manager, like the free Dr. Queue you can let that spread you render over several machines. You'll have to render to an image sequence though.
alano
Post by alano »
The actions go with the Moho file so if you insert one Moho file into another, the actions for the original file are available in the new one.
Alan
Get some "Good Advice" at www.decksawash.net
kingace
Post by kingace »
jorgy
Some details would be terrific, thanks alot for the offer!
It looks like I'd need to write a shell script to make it work with moho?
Lost Marble
Post by Lost Marble »
kingace wrote:Some details would be terrific, thanks alot for the offer!
Here's some info on command-line rendering:
http://www.lostmarble.com/forum/viewtopic.php?t=1318
kingace wrote:It looks like I'd need to write a shell script to make it work with moho?
Possibly. I'm not familiar with Dr. Queue, but Moho only handles the rendering aspect. Dr. Queue (or a similar program) should handle the coordination of multiple machines, networking, syncing, etc. This may require some scripting by you, or you may just need to enter in the command line text to launch Moho.
kingace
Post by kingace »
Cool.
So I suppose, I could have the Moho file on 3 computers, and on the first computer, I only render frames 0-300, second, 301-600, third 601-900, and then use a movie editor to combines the videos?
jorgy
Post by jorgy »
kingace wrote:Cool.
Yes, that is probably the easiest way to do it without too much trouble or extra software. Here is a post from LM on how to do it:
jorgy
