Hi
I've a probleme when I import a animation flash from moho in flash 5 it can't read it can you help me?
import in flash 5
import in flash 5
sorry if my english is very very bad but I am french and I'm 14 years old!
OK. Well, I've never had a problem with this -- but then I don't have Flash 5. If it was me, I'd break down the problem first to try to find out what was happening. First, I'd export a one-frame swf from Moho -- say, starting and finishing at frame 1...Try that and see what happens.
Something is odd here since the SWF exported by moho is pretty basic stuff. These are just "plain vanilla" SWF.
Also... Flash 5 is... well... let's put it this way...
... Flash 5 is living in a gated comumity in Florida playing cards and painting landscapes and wondering why its children don't visit anymore... it probably hangs out with Photoshop 5 and MS Word 6, talks about the good ole days and how hard it is to climb stairs.
I use Flash 7 and everyone I talk too says I am way behind the times!
-Vern
-Vern
Macromedia.. (well, Adobe) has said that they will not be releasing the Flash player version 8 for linux. This is also unfortunate because there is an issue with the Flash player version 7 with sound. Makes youtube and other flash-based video players less than useful. http://en.wikipedia.org/wiki/Macromedia ... _platforms
jorgy
--Scott
cribble.net
cribble.net
i found out how :) yes me i did
here is the answer to ya problem m8
kk first download flash player 8 and a avi to gif converter
now export your animation to an avi
convert that to a gif
then import it to library in flash
then right click on the list frame it is called what ever your animation is called
click on type and select graphic
simply drag the frame you have just changed into a graphic onto the page
then just change the frame rate to 24 or whatever frame rate you use
and resize the screen to whatever size you use.
now just insert a new layer and put your sound werever you like:) you will get it perfectly on time every time Smile yay Smile
and there you have it good luck Smil
