edges problem
edges problem
i have this problem with edges. as i'm working with 3d objects, i use shadows (just like the tutorial said) as edges.
but when i move the object or the camera, the edge thickness changes suddenly.
this not only happens with 3d objects, i have had the same situation working with vector layers.
i didn't know if put this comment in general discussion or in bugs reports.
can somebody help me?
or explain why this happens?
Hiddicop
Post by Hiddicop »
The only thing I can think of is turning of scale compensation.
Rai López
Post by Rai López »
...HI! A related ancient post with no other solutions here -->:!:<--
thank you Hiddicop. now it works.
but, as ramón said (gracias ramón, oye, y de paso, ¿te dije que tu ávatar mola? en realidad sí te dije... en fin), this is not the best solution, i'll have to be more careful with any scene in wich i turn off the scale compensation.
the lostmarble team should think in some solution for their new moho boxed version.
here is the whale
Postality
Post by Postality »
looks to me as if you changed the size of the line during the animation somewhere.
might wanna check on that, cause that's the appearance it gives.
However, if this is a 3D object it may be scaling with compensation do to SOME of the object being closer to the camera than the rest of it...
Anime Studio - Ultimate Game Graphics
