Smart bone no longer works the action.
NealF2
Post by NealF2 »
I made an action with a smart bone dial that was working perfectly.
I tweeked it a bit and even though it works in the action timeline it no longer works in the main timeline.
I've created some animation in the main timeline and all was well for a couple of days.
The bone dial still moves but it doesn't move anything that the action was supposed to move. And when I go back into the action, everything works.
I've already checked and all the keyframes in the action are linear.
I know this might be too complex for the forum. But just in case there's an easy fix, I wanted to post it here.
Thanks.
M1 Mac Mini.
Moho Pro 14
Re: Smart bone no longer works the action.
Sounds like you put a bone somewhere in between the smart bone layer and the controlled layer. This can disrupt bone influence while it still looks like it works in the action, because both are keyframed independently there.
NealF2
Post by NealF2 »
Hi.
Not sure what you mean. Which is the smart bone layer and the controlled layer?
And it was working when I finished for the day. Next day, not working. Only that action/smart bone has this happening.
M1 Mac Mini.
Moho Pro 14
- (1) Bone layer w/ smart bone
- - (2) bone or switch layer without any bones
- - - (3) vector or other layer type with keyframes in the smart action
You can have layer (2) without any bones and smart bones will work, but if you add a bone to layer (2) it will interfere with layer (1) bones being able to influence layer (3).
NealF2
Post by NealF2 »
Well, I tried what you suggested and all looks fine.
I think this might be one of those things that defy a simple answer. I'm just going to recreate the action and see what happens.
Luckily it's not too much work.
M1 Mac Mini.
Moho Pro 14
Also, make sure you don't have any bone or other animation channels muted.
NealF2
Post by NealF2 »
Nothing was muted and all the other places were checked for keyframes. I also double checked that they were all linear.
Anyway, I recreated the action and it's working fine. (Of course the other one worked fine for a while, too.)
Thanks for the suggestions.
M1 Mac Mini.
Moho Pro 14
