Moho is crashing after trying to switch tools
kgeetvcartoons
Post by kgeetvcartoons »
When I use the latest version of Moho I'm noticing that if I use transform bone tool or manipulate bone tool the software won't switch tools and when I save it it then crashes. Any fixes?
Re: Moho is crashing after trying to switch tools
Not much to go on, but you could try:
- Checking for any tool shortcut duplicates
- Removing any third-party tools
kgeetvcartoons
I was thinkin the same thing. I have some scripts that may be interfering. Thanks.
kgeetvcartoons
I've gone to my moho content folder and removed them but they still appear. Also I can't remove any 3rd party tools in preferences. I don't understand this at all.
Did you restart Moho after removing them from your content folder?
kgeetvcartoons
Yes I did. I just went into my contents folder and removed the scripts from the scripts folder and manually removed them from the scripts tools folder. It looks like a couple of them are gone. Plus a restart of Moho and my computer! :lol: Overkill!
If nothing else, move your whole user content folder so Moho can't find it.
Stan
Post by Stan »
Or just re-create your content folder. If custom tools appear after a new content folder is created, it means they are installed in your actual Moho program folder. Find them there and delete them, and never install any custom tools in your actual Moho folder.
Another option to try is to find the .settings file in "C:\Users\<your user name>\AppData\Roaming\Lost Marble\Moho Pro\14" (Windows), and delete it. Relaunch Moho and it will re-create the file. You'll reset all settings, but it's still better than having constant crashes.
