Quick drawings
p6r
Quick drawings
Post by p6r »
With the grid you can draw nice heads quickly...
1) To begin you make such simple heads with only circles :
Use the grid (--> 5) to draw and to place easily your circles :
2) Move the different points to make some simple heads first :
3) You easily can change the colors :
4) With the option "draw --> split curves (--> 2)" you can move the new points to make more complex heads :
If someone wants the basic moho file I can send it on my server...
Hope you enjoy it...
alano
Post by alano »
Nice way to make a crowd in a hurry and they all have the same basic look. Thanks for the tip.
Alan
Get some "Good Advice" at www.decksawash.net
Mikdog
Post by Mikdog »
Very cool.
Thanks.
How did you achive symmetry on all your characters? Did you have to update each side seperately?
Mike
p6r
Post by p6r »
Yes... each side seperately... :?
But with the use of the grid it was ok !
This file is IN anime Studio pro but they didn't add the txt file to explain how to use as I told it here...
teotoon
Post by teotoon »
You can use Fazek's Magnet tool for symmetrical distortion.
Rasheed
Post by Rasheed »
Actually, if the left and right side are slightly different (hardly noticable to the untrained eye), it just looks better and less "technical" and "designed". Just my thought on the subject.
Nice workflow, p6r!
p6r
Post by p6r »
@ teotoon :
Thanks for the info... Did you test such a symmetrical distortion with fazek's magnet tool ?
@ Rasheed :
Yes ! You're right !!!
teotoon
Post by teotoon »
Yes, I tested. It works very well. But you should plan the distortion steps carefully and study the tool's capacity. In other words, you should know what you are doing when you click the button. Otherwise, you can easily spoil your model...
