Could Moho Exporter keep the completed task in the list
bintykins
Post by bintykins »
Could the Moho Exporter have a setting to keep the completed task in the list, showing as Done or Completed with the duration in the status column.
Currently I can't see a way to do this and it would help me so much with rendering multiple shots a day (/hour :| ).
or if there is a way, can someone tell me? :)
SimplSam
Re: Could Moho Exporter keep the completed task in the list
Post by SimplSam »
You read my mind. I was thinking the exact same thing the other day when I was using it and repeatedly reloading a saved profile.
It would make sense if we could pin projects, select those for export (eyes), and add notes. Maybe sort as well.
An alternative approach is to use the Command-Line Render, but that generally needs some scripting built around it - to make it more user friendly.
bintykins wrote: Wed Nov 19, 2025 6:56 am Could the Moho Exporter have a setting to keep the completed task in the list, showing as Done or Completed with the duration in the status column.
Currently I can't see a way to do this...if there is a way, can someone tell me? :)
I agree! I use Moho Exporter with EVERY project, and this is something I've wanted/needed for ages. I also wish it would report render stats after a run is completed.
Right now, I have to check the date/time stamps of the rendered output, but this is a hassle and not very precise.
