Curve Profile
J. Baker
Curve Profile
Post by J. Baker »
Correct me if I'm wrong but I thought there was a way to relax a point in a curve profile? Like you could reduce the effect of the curve profile for certain points.
Re: Curve Profile
You mean the C tool (curvature)?
J. Baker
Re: Curve Profile
Post by J. Baker »
No, I thought I saw something about relaxing the curve profile on certain points. Not sure if it was a separate script, built in or maybe something I thought of a while back that would be a cool feature. Hmm...
Re: Curve Profile
That's normally Curvature: Press C, select the points, and drag to the right to relax the points gradually. To just use the default smoothness, I use Ctrl-M.
Or do you mean something else by "relaxing the curve profile on certain points"?
Re: Curve Profile
Could you be thinking of Liquid Shapes? You can adjust the 'blobbiness' of a shape using Blend.
J. Baker
Re: Curve Profile
Post by J. Baker »
Thanks but nope.
For instance.
Make a circle.
Make an spline for the curve profile and set it.
Now i thought there was a method to select a point to reduce the curve profile for part of the shape. Like to reduce it a bit around that point of the shape.
I could be wrong though and may have been a feature request in my head.
Re: Curve Profile
Oh, okay, I think I understand. I'm not aware of anything short of editing the profile shape directly. If I learn otherwise, will let you know.
BTW, on my computer, I just noticed that the Curve Profile effect disappears in the display when the GPU Cache is active and when an unrelated layer is selected. However, this happens only in the display because Ctrl-R renders the effect just fine.
When I disable the GPU Cache, the Curve Profile effect looks fine and persists in the display even after switching to other layers, as expected.
Considering how the GPU Cache operates, I understand why this happens, but I was wondering if you see this too. Just want to be sure since this is the first time I've seen this limitation. (It had been a while since I last used Curve Profile.)
Thanks.
J. Baker
Re: Curve Profile
Post by J. Baker »
I do not have that issue. Not sure what would cause that.
Re: Curve Profile
Interesting. Thanks for checking.
It's not a huge deal since I often animate with GPU Cache disabled (probably why I hadn't noticed before,) but I'll check this on my other computer when I get home and see if it happens there.
J. Baker
Re: Curve Profile
Post by J. Baker »
Maybe try updating your graphics driver. Hope you figure it out. ;)
Re: Curve Profile
Nah, I keep the drivers updated, so maybe it's just this Surface Laptop. I checked the Curve Profile setup with and without the GPU Cache/Acceleration in every release from 14.3 to 12.5, and it's the same, at least on this computer. Thanks for the feedback.
Re: Curve Profile
Oh, wait! Are you on a Mac? If so, I'm wondering if this is an OS thing. Just gathering info.
J. Baker
Re: Curve Profile
Post by J. Baker »
Using a Surface Pro 7 when I tested it. Windows 11.
Re: Curve Profile
Cool! Thanks!
