Shortcuts On Scripts.
BrianLucas
Post by BrianLucas »
Is there a way to assign key shortcuts to installed scripts? If there's a way, I would appreciate your sharing it. Thanks.
Re: Shortcuts On Scripts.
Only if you install it as a tool/button in the toolbar.
BrianLucas
But most scripts are installed as a tool button on the toolbar. So how can I add a keyboard shortcut?
Shizukuishi
Post by Shizukuishi »
Edit>Edit Keyboard Shorcuts, then search for your script
Even with the head in the clouds You can touch the ground
https://marisolpetretto.myportfolio.com/
https://www.linkedin.com/in/marisolpetretto/
