Stroke exposure on closed curves
Shizukuishi
Post by Shizukuishi »
I don't know if this has been reported before, but when you deselect “Round Caps” on a closed curve, it doesn't show squared ones like it correctly does on open curves. Tested on a vanilla version 14.3
Even with the head in the clouds You can touch the ground
https://marisolpetretto.myportfolio.com/
https://www.linkedin.com/in/marisolpetretto/
Re: Stroke exposure on closed curves
Yes, the Round Cap option has been broken for a while, but I took another look and now it appears to affect only the last point in a curve. I was wondering if you're seeing this too...
Shizukuishi
Greenlaw wrote: ↑Sat Aug 30, 2025 8:16 am I was wondering if you're seeing this too...
Sorry for the delay in responding, I was on vacation for a week and slowly slipped into total idleness :roll: I tried it now that I've just gotten home.
Unfortunately, the behavior with paths with three or more points gives me the same result, but I've also noticed that, fortunately, this error only occurs in preview mode and not in rendering, although if you use the stroke exposure tool, there may be different results depending on the angle of the handles...
Ah! This is good to know! Thanks for checking it out and letting me know about the preview/render difference! :)
