Modified Curvature Tool SCRIPT
Shizukuishi
Post by Shizukuishi »
A modified version of the curvature tool with new controls for the handles
https://mohoscripts.com/script/mp_Curvature
VIEWPORT CHANGES:
  • Select and move a point, or multiple points with dragbox (CTRL)
  • Transform point bounding box for multiple points selected
  • Double click on the path to add a point
  • Double click on a point to toggle smooth/peak
  • Hold SHIFT while dragging a handle to constrain the angle, CTRL+SHIFT to allow handle to flip
NEW TOOLBAR FUNCTIONALITIES:
  • Toggle points selection to lasso mode
  • Lock bezier handles
  • Bezier Peaked points: Convert peak point to smooth point while preserving the shape
  • Select which handle you want to flip with +/- button (Both, Left, Right)
  • Display handles relative angles
  • Constrain angle between handles
  • Screen values: Convert relative values to approximated screen values. Different handles with same values always point to the same direction
  • Fixed Increments. Select a value to snap the angle(s)
  • Display handles length in geometric values
Even with the head in the clouds You can touch the ground
https://marisolpetretto.myportfolio.com/
https://www.linkedin.com/in/marisolpetretto/
