Bake Independent Angle SCRIPT
Shizukuishi
Post by Shizukuishi »
https://mohoscripts.com/script/mp_BakeIndependentAngle
Bake independent angle bones at selected bone keyframes. Based on an idea by Lucafranca
Instructions:
- Select bones you want to bake (non independent bones will be ignored)
- Select any bone channel (angle/pos/scale) keyframes in which you want to bake and run the script
- Script will create keyframes at corresponding frames then will auto switch off independent angle for selected bones
Even with the head in the clouds You can touch the ground
https://marisolpetretto.myportfolio.com/
https://www.linkedin.com/in/marisolpetretto/
