Change Playback Mode SCRIPT
Shizukuishi
Post by Shizukuishi »
https://mohoscripts.com/script/mp_Playb ... ayerScript
Toggle from loop or play once
Instructions:
Create a vector layer and embed the script.
The name of the layer will autoupdate and the visibilty icon will control the playback method.
-- Visible => 'Playback [▶Once]' : stops at PlayEnd/ProjEnd*
-- Hidden => 'Playback [▶Loop]' : does nothing (normal looping)
*Note that it doesn't actually stop the playhead but only avoid looping. To correctly stop you still need to hit spacebar or move the playhead from the end frame.
Even with the head in the clouds You can touch the ground
https://marisolpetretto.myportfolio.com/
https://www.linkedin.com/in/marisolpetretto/
