Frame By Frame And Cycles
W Faucheux
Post by W Faucheux »
I animated a short popcorn smoke burst using Moho's frame by frame layer.
Can anyone tell me if there is a way to cycle these frames in this mode? I know you can duplicate and slide each duplication to repeat but can you make a cycle like you can on vector layers?
Thanks for your help.
Re: Frame By Frame And Cycles
Select the last keyframe and set it's interpolation to cycle.
W Faucheux
synthsin75 wrote: ↑Mon Aug 11, 2025 12:23 pm Select the last keyframe and set it's interpolation to cycle.
Thanks so much. It worked fine. This opens a bunch of possibilities. I appreciate your help.
