Thanks a lot Greenlaw!
mmmaarten
Post by mmmaarten »
Hi @greenlaw, I've accidentally bumped into your new fresh tutorial series on youtube and I'm glad I did. I started watching these only as a refresher and to maybe spot some things I didn't know at first after not using Moho for a while and planning to do a new project with Moho.
But while watching the vector drawing episode I will definitely watch them all now as you explain so well not only how you use the tools and some gems that are good to know, but also you tell why these tools are designed to work this, seemingly odd at first, way and what the benefits are over regular vector tools in other software. You also explain very well.
For one I finally now understand better why there's a separation between curves and shapes. Which was puzzling to me before and felt overly complicated to me when I first started using Moho. Now this makes a lot of sense to me and I see the possibiliies, like changing the draw order mid object. Which is super powerful.
I'm sure there will be more useful tips and best practises to learn from the following parts.
You put a lot of work into creating these, but I'm sure it already has benefited so many new and existing users and will benefit a lot of new users to come in the future.
Thanks a lot for creating these!
Adults should play more often
