when i change camera angle myback ground goes weird
Bicknell1999
Post by Bicknell1999 »
hi iv been trying to figure out why, when i move my camera angle to the left side my back does this(picture below) any help would be loved [img][https://imgur.com/a/jTj0UAn/img]
Re: when i change camera angle myback ground goes weird
It's hard to tell what's going on and what your intent is from the image, but I'm guessing the Camera is in orbit around the artwork. If you're not aware of this, the Working Area is a 3D environment, so it's possible to move the Camera around the image, which may be what's going on here.
If you switch the view to Orbit view, you can see where the Camera is in relation to the artwork.
I often find it easier to reset the views in a situation like this and start over. To reset the Camera and Orbit views, use the Reset button in the options bar for each tool. (Pressing Home for each tool works too.)
If that doesn't fix it, it could be that your artwork layer has been displaced in 3D. You might try resetting the layer position and orientation.
Bicknell1999
hi, thanks for the reply i figured it out in the end i just had to dub the background and rotate and it seemed to have sorted it out :)
