is SimpleDialog() crashing my code? - string "lolua: embedded Lua code"]:4: bad argument #1 to 'for iterator' (table exp
JoshuaOkonkwo
Post by JoshuaOkonkwo »
Hello, there is a common problem I'm noticing with writing scripts in Moho.
It seems like this line SimpleDialog() causes this problem:
[string "lolua: embedded Lua code"]:4: bad argument #1 to 'for iterator' (table expected, got nil)
I think this because when I run this debug check, everything runs smoothly until I try to create the dialog instance.
    LM.GUI.Alert(LM.GUI.ALERT_WARNING, "this alert shows before error", nil, nil, "OK")
    local dialog = LM.GUI.SimpleDialog()
    LM.GUI.Alert(LM.GUI.ALERT_WARNING, "this does not show at all", nil, nil, "OK")
I don't know if this has something to do with my computer, or my code, but I've not just noticed this with my code, I've seen it with another.
What can I do?
This part of the software is supposed to create and display a dialog box where the user can enter some values.
I have searched online, on this forum, restarted MOHO several times, tried the script on different documents.
Nothing works.
Hunreal Moves - Available for work.
https://www.behance.net/hunrealmoves
Donations: https://paypal.me/JoIyke
Stan
Re: is SimpleDialog() crashing my code? - string "lolua: embedded Lua code"]:4: bad argument #1 to 'for iterator' (table
Post by Stan »
LM.GUI.SimpleDialog expects two arguments. See here: https://mohoscripting.com/methods/lm.gui-simpledialog.
If you try the Create New Script tool on mohoscripting.com, it will generate you a working example:
local MyScriptDialog = {}
function MyScriptDialog:new()
    local d = LM.GUI.SimpleDialog('', MyScriptDialog)
    local l = d:GetLayout()
    return d
end
function MyScript:Run(moho)
    local dlog = MyScriptDialog:new(moho)
    if (dlog:DoModal() == LM.GUI.MSG_CANCEL) then
        return
    end
end
