Bug in undoing follow path
Hamedss
Post by Hamedss »
Hi friends.
When you follow path a layer by alt+click on path and mistakenly click on a point on your vector art it will completely distorted. No matter . We shouldn't do that but undoing will not solve problem! It will remains forever in another form!
I noticed if you create new layer and follow( alt click) that path again and delete your original vector art And then Undo this operations it will goes well and the strange undo will not shows again.
Re: Bug in undoing follow path
I've seen weird behavior with Follow Path before, so this is not too surprising. Here's something I noticed in this setup, though:
It's a little hard to tell because the word balloons keep covering the timeline, but it looks like a keyframe was created for the fish shape that's distorting it. I'm guessing when you clicked the point, it got keyframed at its real-world position rather than the Follow Path position. In this case, such editing probably should be done at frame zero.
Next time, instead of Undo, check what it looks like on frame 0, or 'unfollow' the path by clicking an empty space, and then checking the position of the item's points on frame 0. Also, remember to remove any unintended keyframes.
I'm not saying you didn't run into a bug here, but these were the things that popped into my mind as I watched the video.
I'll try recreating this error later today and let you know how it goes.
Hamedss
Post by Hamedss »
Thank you my friend. I should say no. The bug still remains on frame zero and makes an offset of path for layer if you alt click follow path ( normal following is working).
The only solution till this time is to create new layer and following path and deleting original layer from there the undo will work.
Moho have challenging bugs.
And 😁 do you know when is later tomorrow?
