Removing Wind from a Switch Layer
daveedwards
Post by daveedwards »
For some reason (probably my mistake), I've got the Wind channel showing up in the Timeline for one of my Switch Layers. I can't seem to have found a way to remove it.
Dave Edwards
Re: Removing Wind from a Switch Layer
Hi Dave!
It could be this bug...
The fix is described in the video.
If the above fix doesn't help, it could be another bug I see from time to time. Try making a keyframe in the channel later in the timeline, then copy and paste it into the keyframe at frame 0. Now delete the keyframes. Does the channel go away then?
Definitely do the first fix, though, regardless, because it can solve other potential problems.
daveedwards
Ausgezeichnet! That fixed it - 10Q, LGD! Glad I'm a supporter.
Dave Edwards
Sure! Glad that helped!
Thanks again for your continued support, Dave. It's very appreciated. I'm working on getting more stuff on the Ko-fi page this week to make it worthwhile. :D
