Another problem with bone targeting
Hamedss
Post by Hamedss »
Hi.
as I said in this post
viewtopic.php?t=37639
targeting smart bone will disable targeting within action
and now targeting will disable bone dynamics.
that's really strange howis this possible
Re: Another problem with bone targeting
Your videos are set to Private so they are not visible to the public. If this is not meant for YouTube, you should set them to Unlisted, and they will appear here. Also, if these videos are related to the cited topic, would it be better to post them there?
I read the description of the issue at the other topic. I'm not sure I understand the problem as described, but I know that, by default, Moho does not pass on data when it's nested more than two levels. I'm sure this is a built-in limit for performance, but I've been able to work around it by using dummy-targets that keep these nested Smart Bones awake. I don't know if this helps or is even relevant to your situation, so just putting it out there.
I'll watch out for the videos. :D
Hamedss
Post by Hamedss »
Greenlaw wrote: Fri Mar 14, 2025 10:33 am Hi,
thanks for warning . i will never notice of private videos!
and please see if it is of nested level problem?
Cool! I can see the videos now. Will take a look later today.
