Pressure control isn't working in Freehand, Wacom tablet, Windows7x64, Moho 14.3
Leks Luci
Post by Leks Luci »
Hello.
In Moho 14.3, I have an issue with brush pen pressure control in Freehand tool, it isn't working for me.
I have Wacom PTK-840 Intuos4 L tablet, Windows 7 64bit SP1. I can't get pen pressure to work as it intended to. In Photoshop and other apps pen pressure works fine.
Best regards
Re: Pressure control isn't working in Freehand, Wacom tablet, Windows7x64, Moho 14.3
Is Windows Ink enabled? You need that checked on to use pressure in Moho.
You can enable Windows Ink from the Wacom control panel.
If Windows Ink needs to be off for another program, I recommend adding Moho-specific settings in the control panel so you can enable Windows Ink just for Moho. Or, if it makes more sense, make program-specific settings for the other program and turn it off there.
Ooohh...I just realized you're on Windows 7, which was quite a long time ago. According to the specs on the Lost Marble website, Moho requires Windows 10 or higher, so some features may not work as expected in Windows 7.
If you don't see Windows Ink on your computer, you may need to install it from a Windows 7 update.
I did a quick search and found this information: Windows Ink not installed?
I hope you can at least get the pressure working. Good luck!
Leks Luci
Post by Leks Luci »
Thanks Greenlaw, it looks like I will be upgrading to Win 10 or 11 soon.
Best regards
Leks
