Bigger Icons...
BrianLucas
Bigger Icons...
Post by BrianLucas »
Hi, is there a way to set the tool icons a little bigger?
Thanks.
GCharb
Re: Bigger Icons...
Post by GCharb »
Besides scaling the entire Windows interface I don't think to !
Re: Bigger Icons...
BrianLucas wrote: Thu Jan 30, 2025 2:58 pm Hi, is there a way to set the tool icons a little bigger?
Thanks.
I'm unsure this will help in this case, but if you're on Windows, try this:
1. Quit Moho.
2. R-Click over the Moho program icon and choose Properties.
3. Click Compatibility, and then click Change High DPI Settings.
4. At the bottom, check on Override High DPI Scaling Behavior and select System or System (Enhanced). (You may have to try both.)
5. Click Okay and Apply the settings.
6. Launch Moho.
In my experience, this makes the Tools window bigger, but it might also make everything in Moho bigger. Worth a try, though.
If these options don't help, switch back to the previous settings.
BrianLucas
Re: Bigger Icons...
Hi, Greenlaw, I appreciate your help, but unfortunately, it didn't work. Thanks. I do believe that Moho's interface should be improved, graphically. What do you think? It's a shame, but free Open Toonz has a better interface (UI).
Maestral
Re: Bigger Icons...
Post by Maestral »
Hope this would still be related to the topic...
From what I learned, reshaping/scaling the Tools window to a custom ratio is not an option.
However, once you start adding scripts, if the window is undocked, it overlaps the docked ones. Making groups within the Tools window brings some ease but could there be an option for 8 columns (i.e.), instead of the default 4? Perhaps having these additional ones (groups?) as separate Menu bars or even separate windows, with a shortcut to activate them?
