Motion graph channels
Hamedss
Post by Hamedss »
Hi. I noticed some of channels will not shown on the motion graph. Is this true? If you for example change layer fill color in timeline it will be animated and the keys shown on timeline but I can not see the keys and graph ( and channel) in motion graph. I want to use bezier handles to control the change of layer fill color. But where is the keys and graphs?
Note: I didn't consolidated channel.
Maestral
Re: Motion graph channels
Post by Maestral »
FAIK, beziers or keys in Motion graph are available only for xy and z.
Double click on the icon, on the left, and the keys would appear whether consolidated or separated.
Check the settings for Timeline Channels under View/Timeline Channels/
I believe all channels are enabled by default but if you can't see the kf for fill colour change - I'd check those settings again.
Hamedss
Post by Hamedss »
Maestral wrote: Mon Jan 20, 2025 7:54 am FAIK, beziers or keys in Motion graph are available only for xy and z.
Thanks .That's the answer I am looking for. So I should try the smart action.
Maestral
Post by Maestral »
I believe so, especially if you add a wider span of keyframes in SA. This way you'd have more room for fine adjustments.
However, combining available types of kf's (linear, smooth, easing...) would still apply to fill kf's, on the timeline.
