Some suggestions
Hamedss
Some suggestions
Post by Hamedss »
Hi. I grab my post in general discussion to here that is right place.
Undoubtedly Moho is awesome animation software.
It has many great aspects with user friendly ui.
But it lacks some "should be" features.
I hope you countie this topic and viewed by dev team.
Let me start it with simple features!
1- Filet or chamfer points:
It split a point into 2 point and make a corner shape to round corner.
I know there's scripts for it but bear with me ,this is simple option that can be found in almost every drawing program.
2. Split break point:
Simply break the points into 2 disconnected points. This will open the shape and fill removed!
3. Cutter tool:
Similar to above tool cut vector(s) with a sharp knife and splitting them. It can be with option that hold the fills. Like cutting the 🧀.
4. Put origin to layer central point:
That's annoying but needed.
5. All Group Layer collapse-expand:
I wonder why this is not integrated into right click menu yet hope see it soon!
6. Smart action driven not only with bone rotation but the bone position and scale .I am not sure about position because it is point2(or 3) parameter but scale seems no problem
7. Better noise interpolation:
the default noise interpolation is snappy mean it not change between values but just snaps. the noise can be smoother. I do not know how to describe this but the best example is noisy water surface.
8. Undo Redo levels:
I think it is an option that missed from Moho preferences. it is better we can choose how many undo can taken in a file.
9. Spinner Undo:
if we change a value by dragging mouse on it and any change during this single action eat one of valuable Undos! Imagine you change a value like x postion by dragging on it from 1 to 10.now if you undo it will go from 10 - 9.75 - 9.5 - 9.25 - 9 - 8.75.........2.25 -1 and takes about 30 undos! may the Victor Save us :wink:
10-round cap option:
First it need cap start- end option
Then
When you turn off round cap option in advanced style window it works well for end points but if you try stroke exposure tool and get near the middle points a round circle appears in every middle point!
I noticed this when I tried noisy outlines in vector tab of layer setting. This circles are on every middle point.
Thanks dev for hard works
Add your suggestions blew there plz!
