MacBook makes clicking sounds when using Moho Paint Bucket
Gregie
Post by Gregie »
Just wanted to see if anyone else is experiencing the same weirdness. The more complex the shape (more points) the more the clicking occurs. It's happening during the calculation phase when Moho is trying to layout a path for the Paint Bucket tool. Also the noise is not coming from the speakers as I could be on headphones or putting out audio to my main monitor. It's almost sounds like tiny little physical clicks inside the MacBook Pro.
I'm using the M3 MBP , 18gb ram. Mac OS 15.1.1
It's not a major issue or anything just something that's a bit odd so I figure I'd mention it in case anyone else has run into the same thing.
Re: MacBook makes clicking sounds when using Moho Paint Bucket
Moho usually makes a click sound when it welds points together, like welding a curve to make a closed shape.
That's likely what you're hearing, as the paint bucket makes closed shapes.
Gregie
Post by Gregie »
Ahh... thank you! Mystery solved :)
There's an option in Preferences for enabling audio feedback, under the Tools tab. It's on by default, but I keep it turned off so I don't have to hear Moho beep.
Gregie
Post by Gregie »
Thanks Greenlaw, located it and uncheck marked it!
