Rotation causes unintended scaling - Please Help!
animationfan
Post by animationfan »
This learning curve is proving to be more challenging than I thought. Well to put it simply, I drew a square shape into the artboard, and using a simple transformer tool did the rotation animation and guess what it scales. no matter what shape I tried. With layer being selected it works as intended BUT setting the ORGIN to the center is a pain(at least I went through forum and didn't find anything straight forward). Cant it be done simply with the T tool? Well I am coming from After effects.
Re: Rotation causes unintended scaling - Please Help!
If I understand the description of the problem, Moho shouldn't be doing that. I'm guessing there's something odd about the setup. Can you post a sample project?
One thing to be careful of is not to expect Moho to work exactly like After Effects. As layer-based animation programs, they share similarities, but the programs are quite different in many ways. In my experience, some things work better in Moho, and other things are better in Ae. But they do compliment each other nicely. Over time, you'll figure it out.
FYI, I work routinly with After Effects...in fact, almost everything on our Little Green Dog Channel, was created using Moho with After Effects. I also used Moho with Ae for much of my DreamWorks Animation work.
I'm planning a mini-series about my Moho-After Effects workflow for next year, but in the meantime, feel free to ask questions here.
If you rotate the layer, it will work as you expect. If you rotate the points, each individual point will move to reach its new position.
Ah, that makes sense! Thanks for chiming in, Victor.
@animationfan, yes, in Ae terms, this is kinda like the difference between editing the path in a Shape layer vs. transforming the Shape...these can have different origins. And,of course in Ae, the layer itself has yet another origin.
When editing the points in a Moho vector layer using Trasform Points, the origin does not remain fixed, as this would cause problems as you continue to draw in the layer.
If you need a fixed origin, you should either move the art closer to the layer origin or move the layer origin to the desired position. Then, use the Transform Layer tool to transform the layer.
Note that moving the layer origin is more helpful in the rigging and animation stages and not particularly helpful for drawing. In the drawing rigging stage, it's generally good practice to avoid transforming the layers and groups at frame 0. You can do it; just be aware of the transformation issues that can occur if you edit the layers after you've begun animating the project.
Bonus tip: In Ae, I often work with a hierarchy of nulls so I can have different 'origins' for an item to transform or animate with. In Moho, you can sort of do this by nesting Group layers, and giving each Group a unique origin position.
animationfan
Greenlaw wrote: Tue Dec 24, 2024 11:56 am If I understand the description of the problem, Moho shouldn't be doing that. I'm guessing there's something odd about the setup. Can you post a sample project?
oh GREAT! I am in for the Moho Aftereffects workflow tuts, and yes I am one of your subscriber! have seen your vector drawing tutorial. Well here is the file please checkhttps://filebin.net/096pdt8h6mumhm0x/Square.moho
