Are my old Moho Pro version 12.5.1 files compatible with Moho 14 Pro?
Doc9
Post by Doc9 »
I want to know if I can open my Moho Pro version 12.5.1 files in the newest Moho 14 Pro release without having issues with the old files? Is it possible that my animations, gradients or colors look different or distorted when I open them in Moho 14 Pro? I export my animations as .png files.
Re: Are my old Moho Pro version 12.5.1 files compatible with Moho 14 Pro?
I can open old Moho files back to v9.5, so you're safe. The content remains unchanged.
For the most part, Moho 12.5 files should be good in Moho 14.2. I've had to reset labels and a few other options that didn't carry over, but it was not a big deal. Keep Moho 12.5 on your computer so you can compare the results and behavior after importing to Moho 14.2
Tip: Don't reuse settings files from older versions of Moho, and I recommend starting with a clean Content folder. Copy over your custom content (brushes, templates, etc.) by folder, and press Ctrl+Shift+Alt+L to check they're okay after each copy. If you use third-party scripts, you'll want to test them one at a time. Some old scripts for Moho 12.5 (or 13.5 for that matter) are either unnecessary now or broken in Moho 14.2.
