Long standing bug: select color from the other color swatch
This bug has been around for forever but let's say you want your fill and line color the same in the styles window. So you set up your fill color and then take the eyedropper tool from the stroke color and select the fill color from above. If you look closely, they are not the same. Double check their Hex Codes. I think it would be nice to finally fix this.
