Huion Tablet Freehand brush laggy
jcan310
Post by jcan310 »
I use Huion RTP-700. And I moho 14.2. When I use freehand brush with Windows Ink on, cursor is shaking and feels laggy. When I turned off Windows Ink It disappeared, but pen pressure is also dissapeared. How can I fix it? I searched every forum and reddit. Nobody can fix it.
Maestral
Re: Huion Tablet Freehand brush laggy
Post by Maestral »
There's always a possibility of tablet malfunction or hw insufficiency. The rest is usually in the settings.
Check the drivers and see if they match. Also, check the graphics settings on your machine.
Lag could be caused by inappropriate spacing for the brush (large and too dense brush stroke brings high demands for hw)
Shaking can be as simple as holding the pen neither too close nor too far from the tablet's surface. Try it with some foil over it.
There's a that set of touch buttons and a slider on this model - perhaps some are under your arm?
As somebody who for the first time got a non-Wacom device i can confirm that Moho doesn‘t play very nicely with them. I still got a cintiq at the office and the pen experience feels much more fluid with that. *sigh* can‘t have cheap things in life :D
(All other apps i‘m using are working fine tho)
Hi @jcan310,
I'm sorry to hear you're still having the problem with the Huion tablet. As mentioned the other day at my YouTube channel, I think I have an older model Huion tablet stashed away here. I'll look for it this weekend, see if I can reproduce the lag, and hopefully find a solution.
