Bezier handles not working properly VIDEO FOOTAGE! UPDATE!
kgeetvcartoons
Post by kgeetvcartoons »
I can't use my Bezier handles. There are not fixed even though the fixed Bezier button is active. Now My handles move for no reason messing up animations and actions are impossible to do. Using the handles affects other points. I can't move forward and I'm updating all my characters for an upcoming series I'm creating. Moho as of late is having issues. Characters that worked just fine a couple days ago are now not moving properly and layers that were binded are not properly binded when I move them.
Is anybody else experiencing this?
https://drive.google.com/file/d/1pSg8RS ... sp=sharing
A brilliant guy by the name of SimplSam helped me with the glitchy issue! I just had to pick the "curvature tool" and click "show bezier handles". BOOM it's working again!
Last edited by kgeetvcartoons on Thu Oct 17, 2024 11:40 am, edited 2 times in total.
kgeetvcartoons
Re: Bezier handles not working properly
I even did an uninstall and reinstall and the bezier handles don't work. When I try to grab and handle it picks the nearest point and moves it. YES FIXED BEZIER HANDLES BUTTON IS ACTIVE!
Is anyone else having this problem? Also I notice my other characters that previously had no problems now have animation and basic problems like layers not behaving properly. I don't know if the latest windows update did anything to MOHO but now I'm stuck. I can't update the rest of my characters for an upcoming series. I can't even do basic actionS because the bezier handles are moving points that should not be moving!
AGGRAVATING AS HELL!
SimplSam
Post by SimplSam »
So there was a 'fixed handle' bug that was caused when Show Handles was Set or sometimes Not Set on the Curvature tool. Try checking/changing that.
I think that bug is still hanging around.
kgeetvcartoons
Re: Bezier handles not working properly VIDEO FOOTAGE!
Are you talking about the "create curver layer tool"? If that's not it what is the "Curvature tool"? Is that the same tool? I don't think I've ever used that. Is it called something else? I know that may seem like a simple question but I just use this software without knowing all the tool names.
kgeetvcartoons
JESUS CHRIST I use this tool all the time!!! 🤣🤣🤣🤣 Nevermind! I just use without really knowing the names. Anyway I'm checking to see if I can get the bug away! Thanks.
kgeetvcartoons
Update. By checking it it's fixed! Thank you!
Re: Bezier handles not working properly VIDEO FOOTAGE! UPDATE!
I believe it's the option inside the Curvature tool's option that throws the Bezier hanndles setting out of sync. Whenever the handles lock up for me, that's the first thing I check.
The option stays in sync between Transform Points and Add Points, but the one in Curvature can throw it off for all three. Changing the Curvature tool's Bezier handles option to match the other two should correct it.
BTW, Synthsin75's Curvature tool mod added the Bezier Handles option for older versions of Moho and correctly kept the settings for all three tools in sync.
Hopefully, we'll see a similar fix for the new option in Curvature for Moho 14.x.
To be clear, Moho thinks the handles are hidden, so it won't let you select them even though you can see them. Enable or disable the option in Curvature should unconfuse Moho, and Moho will thank you for it.
