warp problem
Hamedss
warp problem
Post by Hamedss »
HI.
can any one help me with this:
I created 2 vector layer. Layer 1 Layer2
Before I filled the layer 1 with the help of "fill the quad mesh" script, I used layer 1 as warp in the settings of layer 2 and it turned out like this
I know that this mode means curver layer, now there is no way to return this layer to normal mode other than undoing?
I deselect the layer 1 in layer 2 warp setting. still no luck!
how to get ride of this :arrow: https://fileport.io/n6wm2dHJasTk
Re: warp problem
create a new vector layer.
go back to the curver layer.
make sure you just have the 12 points visible (Moho actually creates extra points but they're hidden) then with the select point tool active Select ALL (ctrl-a) and Copy (ctrl-c)
back to the new vector layer and paste (ctrl-v)
you now have an empty grid of those 12 points.
Hamedss
Re: warp problem
Post by Hamedss »
Oh thanks. copying it in another vector layer saved me!
