moho 14.2 layer select crash moho!!
AHMED003ADALAT
Post by AHMED003ADALAT »
Hey guys, i have an issue, almost everytime i select any layer by R click mouse button the layer moho crashes.....that happens after i made my vector character with some boil effect🤔
Re: moho 14.2 layer select crash moho!!
sounds to be the same as this issue: viewtopic.php?t=37291
can you upload a problem file?
AHMED003ADALAT
hayasidist wrote: ↑Wed Aug 07, 2024 5:27 am sounds to be the same as this issue: viewtopic.php?t=37291
sure here is the project i was working on..... just select any of the face details by R-click mouse button and it'll crash with you without any messages or log🤷‍♂️
https://drive.google.com/file/d/1oqEQ_9 ... sp=sharing
all ok here. can't break it. Moho 14.2 20240525 Win 10 NVIDIA GeForce GTX960
AHMED003ADALAT
hayasidist wrote: ↑Wed Aug 07, 2024 6:21 am all ok here. can't break it. Moho 14.2 20240525 Win 10 NVIDIA GeForce GTX960
i don't know why exactly but it seems good now....... deleted couple of unused scripts, mad the image txt from tiles to don't repeat and turned off through transpirancy that seemed to have some conflicts with mask or some glitches.
i even revert image txt to old settings and working fine now so it seem some glitch in the image txt part but all good now, thanks alot my friend i appreciate the great help here🙏🙏
SimplSam
Post by SimplSam »
It did crash for me with all the images loaded - but not when the assets were 'not-found'. But you have resolution - so all good.
SimplSam wrote: ↑Wed Aug 07, 2024 9:50 am It did crash for me with all the images loaded - but not when the assets were 'not-found'. But you have resolution - so all good.
that's interesting ... some of the images are used as "image texture" to vector shapes which OP says they "re-set" to avoid the crash...
I downloaded the .zip and copied the pinkguy folder to a working directory -- and (here come's the BIG guess) when I loaded the .moho, it looked in the project folder for the texture files -- which, as that folder was newly copied, were found -- which now makes me wonder (here and in the other such report) if the issue is with "broken" references to image textures that only manifest themselves in the original storage location [i.e. doing the equivalent of a "gather media", save resulting files and then loading the moho from a new directory results in a correction to the path to the image assets?!]
AHMED003ADALAT
hayasidist wrote: ↑Wed Aug 07, 2024 12:04 pm
that's an interesting approach as it didn't get me any message for the crash and when i open moho again it tell my that it crashed and recover file.
R-click mouse layer select works fine now after removing an unused and only script i have ...... but most likely issue fixed after i choose don't repeat tiles and uncheck through transperancy also, it seems there might be some conflict with moho with this 2 options specially when all layers with victor boil feature........ i don't know but i'm sharing my experience so far🤷‍♂️👍🙏
jeremiahbabers
Post by jeremiahbabers »
same here. i shouldnt have go to an image tiler site to manually tile my images. also brushes STILL crash moho with layer selecter :x
